1 - 3 of 3 Posts
Last evening, I decided to add my AUX lights. I did not complete the job for want of two bits of info. First, I could only get the bottom of fuse cover open and thus no access to the AUX section at the top. Secondly, is this AUX terminal switched or not ( IE does it drop power when the ignition is off or is it always on).
Lastly, if I take the time to tear the front off to change the cornering lights, is it an easy enough job to make them stay on all the time? (or is that eve a good idea?)
aux is off when the key is in the "off" position.... it is on when the key is in the "A" or "Aux" position AND when the key is on
Senior Guru
hi the fuse cover has a clip on the top also you might need to remove the seat to get at it, if you go to the goldwing tips page the info is there to wire the cornering lights to stay on
http://www.goldwingfacts.com/GoldwingTips.htm
1 - 3 of 3 Posts
