We got er done Bearings and fork bolts.
On the good bolt used a proper 6mm allen on an air impact wrench, didn't work.
Went to the other damaged bolt drove in T45 bit came out slick even though it was only driven in less than 1/8". Same on the previously good spining side. Did not have to remove fork cap.
Used the split bolt and screwdriver trick for bearings. Would not bite on bearing
had to spread it on the inner spacer. You definatly need at least a hand held sledge.
They faught all the way out!
Hey Spider I want some of what your taking:cooldevil:, so where should I look for bolts?
Thanks all U saved me about 45 bucks. I ordered a bearing removal tool last nite from old bike parts but the website screwed up and it didn't go through:cheeky1::cheeky1::cheeky1:
