SpiderBob wrote:
Funny I have never seen a thin fork brace. :?I've seen none on the 1500 except for the under brace that secures the fenders together, is that what you are referring to? But mine is quite stout.
Perhaps I mis-labeled it, but yes - that is what I was referring to. The only structure between the lower fork legs
(besides the axle) on the 1500 is a mild steel stamping, positioned under the fender, where it is subject to corrosion.
Thepiece between the lower fork legs
(besides the axle) onthe 1200 is a rigid, cross-braced, corrosion resistant alloy casting, positioned above the fender.
