Hi all,
Can I simply swap the fork caps on my 1989 GL1500 US spec for the later ones so I can add air. Or should I just drill out the existing ones and add schrader valves?
I am hoping to just stiffen up the front end cheaply, rather than going to the expense of adding progressive springs. :shock:
I am about to change the upper bushes, oil, and seals, so now is as good a time as any.
Has anyone already done this? If so has it made an improvement? :baffled:
Hi all,
