Yep... take the drain bolts out, pump the forks up and down until no more comes out, put the drain bolts back in, andfill with the recommended oil. If BRowan's figures are right, add 323cc's (or 323ml) to each leg.I have the Haynes manual and it says that Honda don't specify a level for the fork oil, only an amount; 323cc each leg for drain and refill, 345cc after overhaul.
