I need to stiffen up the suspension of my 95 GL1500SE. My wife and me weigh about 470 pounds (combined) and we usually travel fully loaded (Weight limits in all compartments exceeded) and we pull a kwik kamp. I know I need to swap out my rear shocks with 416s and put progressive springs up front BUT until them I am thinking of replacing the oil in the forks and rear shock with 20wt fork oil.
My question is, is this too heavy of a fork oil weight for the rear or front? The book says I can go as high as 30wt up front and new ATF fluid was put in last fall but it is still too soft. I also plan on thinning the 20wt with some ATF leak stop just as a preventative measure to keep seals lubed.
