1 - 13 of 13 Posts
Has anyone made a set of tunnel blockers for the forks? If so do yo have a "spec" diagram?
Thanks,
I've got this one I got from somewhere (forget now, apologies to the original poster). Note: this is for the 1800!
Is there a reason that tunnel would have to be open at anytime?
I get a lot of road debris up through there when I'm riding, bugs, grass clippings that are blown out onto the road, leaves, water when it's raining or roads are wet.
I have the fender extension in the front. I was thinking of getting some soft thin rubber to extend it down another inch or so, and use that same rubber material to built a permanent shield inside the tunnel.
Piaggio MP3, was 02 GL1800
I can't think of a single good reason to leave it open.
I get dust debris in my eyes, even under my eyeglasses unless I keep my helmet fully closed.
I lost my old tunnel fillers when my '94 was killed by Penske.
Need to make some new ones or just let CycleMax send me some. that is easier.
Gregarious Greeter
Never did understand why Honda did not put a rubber boot over that opening like the boot over a c-v joint.
That's weird, I don't get this debris through there and I ride with an open-face helmet with the visor up. Maybe the windscreen makes a difference? I swapped the stock one for a FireCreek one years ago. Even water through that opening is not a problem for me.
1993 gl1500, 1976 gl1000
I also don't recall ever getting anything noticeable up through the openings. Perhaps road noise but????
Maybe 1500s don't do it but I would get water up through the tunnel riding in rain, not a lot but some before I put the tunnel filters in. I do think it helps keep the dust down and helps the air filter stay clean longer. I do know the tunnel filters in my old 1800 got real nasty, I was going to salvage them until I pulled them out of the wreck and saw how dirty they were.
Just another ORF!
Hardly any difference
I just reinstalled a set on my 1500 ...... and there is very minimal difference (if any) than without them. :baffling:
life is good
i will not ride without them. i think they make a big difference. i don't like all the air coming up thought there. i keep my windshield vent closed almost all the time. its the extra air i don't want. in the summer the air at 70 mph is like a hairdryer!:)
1 - 13 of 13 Posts
