The problem with that is it will vary with battery voltage instead of holding a constant 7 volts.
Or if the resistors used to regulate the voltage change values over time....
That regulator can only handle 1.5 amps. You have a 30 amp system.
OK, now I see your other post. You need a regulator for the 7 volts. There is a better chance that will work. I never owned an 1100, so I can't help with the 7 volt problems.
