I imagine the Master Cylinders will work fine.
This being a closed properly bled System, The piston throw is enough to exert the force you need.
The real question will be is how the proportion valve handles the difference in braking when the pressure is shared from rear bakes to the left caliper on the front.
Now that you will have quite a big gain in difference in braking from a stock system.
But if things are equal but increased efficiency. This problem may not even be a problem.
Either way, Be sure and send us some pics on your mounting of the Calipers and the new feel of the brakes.
Good Luck and great Idea.
Mohawk
