Check your coils. You'll have to pull the false cover. The plug on an 83 is on the left behing the steering stem. There will be three wires, probably blue, yellow and black. Open the connector and clean the plug on the loom side with CDC or some electric cleaner. Pull the coils and clean all connection on them including the spark plugs. Check the primary and secondary coil resistances and replace any coil that is out of spec. Check the resistance on the plug wire and cap. It should be 5K +/- 10%. Hope this helps. LOL!!!
