Pacific Coast 800??? If you can stand the '80s "Flock of Seagulls" look.
You are nearly describing the Burgman 650she can't stand more than an hour or so at a time on it because of the leaning-forward riding position, and in particular, the clutch.
She would love a more upright-seating bike like my Goldwing, but she's 5'7, 115 lbs and in no way capable of handling a bike that big/heavy (her words, and I tend to agree with her).
She'd also like a bike with some storage capacity
Yup, already tried that for her. Problem is, you can't rotate it too far, or else you don't have enough of your hand left holding your body up.Don't forget - you can loosen and rotate the brake/clutch on most bikes. Often the clutch/brake levers are set too high, and you must rotate your hand so your wrist is low and your fingers up That's just improper ergonomics.
rotate the assemblies to raise the wrist and that might be a partial solution.
Wingman 71 is talking gospel here...... I got a riser plate (not helibar) for my ST1300, which made the bike as comfortable (or near enough, anyway) as a Wing..... might work, if they make them for the SV650. The SV650 is a good bike; my son has madeseveral longish trips on his SV, although he has no risers...... UBarW is also talking gospel, however, about the remarkable Wee Strom, which is one of the most comfortable bikes I have ever sat upon..... I still wonder if I should have bought the Wee Strom instead of my ST1300....... If something ever happens to the ST, and I survive (!), I think I'd buy a Wee Strom in a heartbeat.....GS,
A good friend of mine got an SV-1000S because he liked his son's SV-650S. However, he's 55 years old and soon tired of the bent-way-the-heck-over, too-much-weight-on-his-hands, riding position.
At my suggestion, he solved it by adding a set of "HeliBars" handlebar risers onto his bike.
http://www.helibars.com
Perfect solution! Not cheap, but great product. They brought the riding position up and back just enough to do the trick. He's a happy camper now.
So, if your friend is leaving the option of keeping the SV-650 open, then just add some HeliBars and then add some soft saddlebags for storage space when taking long trips.
One of my very best friends currently has a Suzuki SV-650. It's her second bike, and she loves to ride it. She's a fairly skilled rider, and has been riding for about eight years.
However, she can't stand more than an hour or so at a time on it because of the leaning-forward riding position, and in particular, the clutch. I had the exact same problem on my GSX-R750 - because my left hand was bent upwards holding my body up, and because the clutch was so stiff, I would get incredibly painful carpal tunnel, to the point where I couldn't ride the bike. She has the same problem, and she will go without riding for periods of time because her left wrist hurts too much.
She'd also like a bike with some storage capacity - her SV650 has enough space to hold a wallet and a set of keys under the seat, and that's a tight fit.
So...can anyone recommend a bike that might be a good fit for her? Something with a hydraulic clutch would probably be a good idea, or at least something without heavy clutch springs.
yup...suzuki vstrom 650
adios
fast black
I think the stock one is 3 and something gallons, don't remember. IMS makes like a 6.5 or something for it.fast black wrote:yup...suzuki vstrom 650
adios
fast black
That motard has a tiny tank, though, doesnt it?
