I have a warped front disc on the left side on my 83 Aspy. I bought a set of used 83 front discs and the hub portion is different looking.My Aspy had a solid cast hub and the ones I bought have cast "spokes". I am gathering they are from an interstate? As far as I can tell they are the same dimensionally. Are they?
Can you turn a front disc to take out the warp like on a car/truck? Mine measure .385" (9.7 mm).
I have measured the thickness with a mic and they are similar, within reason,and thicker than the 9mm minimum.
The height from hub face to disc seems to be the same, eye balling them sitting side by side on the bench top.
Am I mising something or are they just a different Hub style and they should work fine?
