1 - 3 of 3 Posts
1983 1100 Aspy Front Brake Reservoir Removal??
How the heck does the front brake reservoir come off.
Thought I remembered reading it is simply held on by an o-ring after the top cover and rubber diaphragm are taken off- after removing the two top cover screws.
Have prudently tried to pry the reservoir up with my putty knive.Don't want to ruin my plastic/vinyl reservoir learning what not to do!
Thanks,
Rod
it is sealed by a O ring and it might have hardened making it stubborn to remove . by turning it you maybe able to get it loosen up some. twisting and prying at the same time. watch out for the fluid getting on the plastics .
mileage 16,000 . is that your mileage ? or is that speedo mileage ? sure is low for a 83.
You're RIGHT. 28 years since assembly makes for a stubborn SOB!
Thanks for the reply & help. Rod
1 - 3 of 3 Posts
