Well, finally got time to change out the front fork oil. MyHonda manual says do one at a time so I started with the rightshock. Drained the oil as instructed and then jacked up thefront wheel and removed thecap. Added the required amount of ATF and see no way of compressing the spring enough to screw the cap back on.
Is there some trick to this? Would it make any difference if both shocks were done at the same time?
