I have had a recurring problem with my GL1100i since I got it last July. The front forks both leaked. I had the forks rebuilt and the right side seems OK but the left one still leaks and they will not hold air.
I purchased a replacement set of forks along with another set of seals rings and dust covers. I also decided to install the on board air compressor from an Aspy so I could adjust them on the fly depending on weight requirements.
The standard forks have the elongated tops with the air fitting and the hose that runs from the right to the left fork. The new forks have an indented fitting in them that appears to take an Allen wrench to remove.
The air compressor has a metal tube that appears to somehow attach to each forks with an air fitting on it as well. I think I have a combination of 1100 and 1200 parts and am completely confused on how this would be installed.
Has anyone done this or have any suggestion on where I could find instructions or schematics on how this would go together?
:baffled:
I can supply photos of what I have if that would help.
:stumped:
:baffled:
:stumped:
