1 - 20 of 31 Posts
My front tyre has been loosing air over a 2-3 week period and was almost flat at one point after not using it for a short period.
lost about 6 psi in less than a week.
It had a new K177 fitted last year and only a few thousand miles done since.
This morning I put pressure unto 50psi and went round the whole rim, valve, tyre with soapy water.
Could not find a thing to explain loss of air.
Next I was going to remove tyre and take it too garage so they can submerge whole wheel.
Any thoughts or bright ideas before i do this ?
thanks
Just another ORF!
Robin ... if you have an OEM air valve, try flexing it a little bit, while soaking the area around it with soapy water. More often than not, they begin to tear and leak but are hard to detect, unless moving it around a bit, which simulates actual usage. That's why I switched type/make of air valve.
If that's not it, I suspect that the bead area of the inner rim wasn't cleaned before installation of new tire, .... barring any puncture in the tire itself. :?
Nail in tread, still in there = slow leak..
I have the same problem, i looked and looked and could not find the leak, tried soapy water,new valve core, wiggled the stem, no luck.
Finally modified a plastic tub to submerge part of the tire and rim under water and wa la !!! found 3 very, very small trickles of smaaaal trickle of bubbles at the bead. Will have to remove the tire at some point and hopefully get it sealed.
Good Luck Jim
Cant see any nail.
Yes its an OEM valve and stem, it was new last year but worth a wiggle to see if its that.
I put loads of soapy water around the rim, to see leak there, nothing.
Cheers
thats horrible stuff. :-(
When I changed tyre it had slime inside wheel which had gone rancid.
(fitted by previous owner).
I use dyno beads for balance which so far have worked very well (no beads stuck in valve, I have checked ).
Robin- As i said i tried the soapy water and bubble blower stuff ( use to use it to fing propane leaks ) and not untill i submerger the tire and rim did i find the leak, and even then they are very small and hard to see.
Jim
Thanks Jim
Will give that a go, I have a sneaking feeling about the rim bead.
Just need to find a big bucket :)
Check the valve stem Core... confirming that it is tight.
Also, since the core's sometimes leak, it is good insurance to use a valve stem Cap that has an O-ring inside it, to stop any leakage from the valve core.
Discussion Starter #11
Hi Alex,
thanks, I put in a new core first time I noticed it was going down, I will recheck how tight it is.
Getting stem caps with o rings in always seems to be a problem, reminds me to order some more off ebay.
Are you using Dynabeads to balance the tire?... many people have experienced leaks, resulting from the beads residing in the valve stem, causing it to not fully seal.
Discussion Starter #13
yes I am using dyne beads and have made sure the valve core is bead free, no air is coming out of valve.
I am going to have to remove wheel and put in water as next stage to see where its leaking from.
My tire never goes flat, but it seems to love about 30PSI LOL
I air up to 42PSI and sometime later it's at about 30PSI.
Only seems to leak down when sitting.
I let the wing sit about a week, checked air to go for a ride, 40PSI
Never have found any bubbles but I have not taken the wheel off for a bath yet either.
Long as I air up before riding (if needed) tire does not loose the air till it sits at least over night or longer.
usually the shop will just swap em out and dont give a [email protected]#@#$
how gummed or crusty the rim is...you or who? needs to do this task personally once and a while to detail and clean the rim up good or this fun issue can plague you thru the life of the rim.
Soapy water doesn't always find a leak but submersion will.
Discussion Starter #17
Agree as found zip with soapy water, wheel is coming off in a few days to do just that.
i've found that windex will find a small leak quicker than soapy water
Disfunctional Nimatode
A wheelbarrow works good to put water in.
Just another ORF!
That's why whenever I change mine, or anyone else's tire, I always scrub/clean the inner lip of the rim, where it makes contact with the tire's bead.
The insides of my rims are cleaner than the outsides! :D
1 - 20 of 31 Posts
