Front wheel bearings - size?
1226 Views 5 Replies 4 Participants Last post by  slickster
Are these the symptoms - noise and vibration when going around corner, but smooth when going straight?
Yes, I'm going to put it on stand to see if I can feel roughness.
Like to know for now if I can go to my local bearing supply house for replacements?
I don't have the specs on them, sorry, but you can get them cheap enough online it's probably not worth going to your local bearing shop anyway. You can get the set, bearings and seals for the front from Dennis Kirk for $16.99 + shipping, for All Balls brand.
The bearing reference numbers are in this thread;
http://www.goldwingfacts.com/forums/view_topic.php?id=73355&forum_id=1
You should be able to cross-ref them on a bearing suppliers site and get the sizes.
[shadow=green]U guys rock - Thanks[/shadow]
U know I'm finding these bearings very common.
But the seals, seems to be confusion - Mrcycle gives sizes as:
22x42x7
40x50x5
Bearing houses say anythng narrower than 7mm is special order besides.
+ u know how narrow 3mm would be.
Eddies Nos decoded wouldbe:
30x42x3
30x50x6
englishted
GWEddie
Guru
BTW the bearing type is 6302-2RS for both sides. You can easily cross-reference that at any bearing supplier.
If you are buying seals seperately, they are;
Front Right Seal 30-4203
Front Left Seal 30-5006
Before you go after the front wheel bearings...take a close look at your front tire....can give you same symptoms....noise/vibration
