:waving:The axle does not need to be removed. On the Aspencade remove the speed sensor from the wheel assembly. Remove the left caliper and bracket by removing the caliper mounting bolts and support the caliper so it doesn't hang from the brake hose. Remove the right and left axle holders. Jack up the bike until the fork legs lift free of the axle and remove the front wheel.Axle must be removed. But manuals download is a great help.
Thats right, just remove the screw to get the cable free and remove wheel. I assumed he wanted to remove the axle and speedo drive unit due to his post. Perhaps I overread it!I thought there is a phillips screw that held in the speedo cable, that's all I did.
Unless you really wanted to grease the axle/speedo drive?
