Is there a suitable replacement I can buy from the local auto stores, napa etc for my 1998 GW SE ? Woops big brain slip I meant 1998
Napa 3003 @ $5
They fit in tight w/o the rubber band holder as they are a little bigger than stock and they are clear to see the condition better. Change the gas filter yearly as well as clean the air filter.
Oh - THAT guy...
x2 on both above.
X3... a good clear-bodied filter.
Pwhoever
You can also check your regular auto parts store for the Wix 33003. It is identical to the NAPA 3003 but sometimes a little cheaper and more available.
