I just changed out the Thermo switch on my 82 Gl1100 Interstate & I also change the antifreeze so I took off the seat & tank. When I put everything back together now my Fuel gauge won't work. Did I pinch a wire or blow a fuse some how? Thanks for any info.
Did you check the connection to the sensor? It is located on the top of the tank under the seat. The connector & wires are exposed whenthe seat is removedand can be moved or damaged.
To Update, I think The seat was putting pressure on the conection. I removed the seat & wiggled the wires & the guage started working.
Thanks everyone for your help.
