any one know how you can figure out a injectors cc's if you cant find information on them? like i tried browsing the internet for certian one's i did find someone who says they know them but you can always trust the internet.
Banned
There are many available on-line calculators available for those that need them...
Some sites are general in their collection of calculators while others are specific. Most use the same basic algorithms for a specific calculator despite the look of the interface. The more input required for calculation, the more specific the sum.
http://www.csgnetwork.com/fiflowcalc.html
http://www.wallaceracing.com/Calculators.htm
Anti-Guru
If you've got a good over the road truck repair shop close-by, they've likely got a flow stand for injector rebuilding and calibration - You can have em flow-check for ya.(remember that diesel injectors are quite diferent than injectors for the thinner fuels so not all diesel shops will be able to help, but it can be a good place to start, or to get another lead for a call)
Working with a GOOD auto/bike store parts counter, they may have a catalog that will cross-reference what you have into something that they may be able to sell (and then, also describe flow/pressures)
At one opint I had a small stand in the back of my shop, but I can not recommend building one as a DIY - there are a few variables that need to be closely controlled for accurate measurements (pressure, available volume, and injector pulse duty cycle) - It can be done with scrap parts and time to fit each injector's inlet cap, but supporting a lot of variety in injectors is a total PITA (thine harness, fuel inlet, somephysical mount, electrical characteristics and flyback handling, consistant pressure regulation) -- and accuracy I always abotu the "fuel" (fake) that you're pumping and its temperature.
Depending on your need, I'd recommend going with the catalog approach (of you're shopping around for something), or if you're interested in knowing what YOUR rates are, contact the guys at http://www.witchhunter.com for a vary affordable servicing with flow-data...
Banned
Oooops... I didn't process that question right. Coffee prior to posting: ohhhh OK.
Edit: Manufacturer (either auto or injector itself) should be available on-line...
http://users.erols.com/srweiss/tableifc.htm
Many results popped-up...
okay well thanks alot guys.. im going to look in to that now. when i have accomplished my goal ill post it for all to see.
