You don't necessarily need to have a tear in the diaphragm material for it to leak from the weep hole. It could have hundreds of small cracks that arevirtually invisiblyin the rubber material, become saturated throughout and work more like a dripping wet sponge causing the leak. I've pics somewhere on here of what I'm talking about. I'll look for 'em.
Rebuilding one is more effort than the worth I get out of the process, but it's definitely doable. I run a rebuilt pump as a back-up until I hit the 10K mile benchmarkwith theelectric pump I use. A "Mr. Gasket" 2-4 psi pump with no external regulator, but I run a single carband have no experience inusing it with the factory rack of carbs (should work fine though, I think). Almost 9K miles with no problems,failuresor worry.
PM RB. He might be able to help if you cannot find another one. eBay is a gamble IMO on these pumps.
