yes, now im disconnecting all, Battery, And the wire. When I disconct The negative Wire on battery, that fuel wire Its stop buzzing..That is almost impossible unless someone has modified the wiring. Have you tried disconnecting it to see if the buzzing stops?
There should be no power to the ECM with the switch off.To me it sounds like the fuel pump is stuck on and running all the time. The sound is radiating through the wire. If it is an 88 or 89 could be bad fuel pump relay. If newer could be a shorted transistor in the ECM. I bet there is power to the pump at all times it is buzzing.
I don't know what to think. Is COVID getting to everyone?There should be no power to the ECM with the switch off.
Someone tell me the purpose of this relay.
Of course I am serious, that relay serves no purpose as it is shown except to kill the engine if the BAS is tripped. IMO it should have a separate power source to really be useful. The title says 94 so I'll assume it's a 94. Looks like the terminal is disconnected and his finger is over the tab it connects to.I don't know what to think. Is COVID getting to everyone?Are you being serious or sarcastic? I realize the relay cuts power to a lot of things including the ECM but what if it is an 88 or 89 with a relay? It is likely not an Aspy or SE as there is no filter on the fuel pump wiring. If you look at the terminal his finger is pointing to it looks like it is just a tab welded to the plate. Wouldn't that be a ground? Shouldn't it have a green wire connected? Puzzling.
Aaaahhhh.... That all makes sense. You had me really scratching my head. I guess I never thought about the relay and now that you mention it I can see where the wire would normally go. Thanks for setting me straight. ///// Well as straight as I get.Of course I am serious, that relay serves no purpose as it is shown except to kill the engine if the BAS is tripped. IMO it should have a separate power source to really be useful. The title says 94 so I'll assume it's a 94. Looks like the terminal is disconnected and his finger is over the tab it connects to.
that's what I'm thinking now... Never change the fuel pump, since 15 Year ago...I think the impeller in the pump is dragging, causing the vibration.
probably need a new fuel pump.
always share Videos, that is how we gain information.if i can share the videos here...
The fuel pump is not the problem, the power to it not shutting off is.that's what I'm thinking now... Never change the fuel pump, since 15 Year ago...
yess many Bees 🤣🤣🤣🤣Do you have any bees in your gas tank?
