Have no power going to fuel pump. Hot wired pump and it is working. Checked fuses in fuse box, all are good. Is there a fuse somewhere else on the bike for the pump? What relay next to the fuse box do I need to check.
Welcome to this Great Site!
Pull up a chair and join on in!
Ride Safe, Ray
:waving:
Try you question in the Tech forum as more folks such as our fine gurus and other 1500 owners will surely find it quicker:action:
The Irish Crew
There is a relay that can go bad, I don't know where it's located as I own a gl1100. I know its been discussed here before, do a search and you will find what you need. And welcome to the forum.
It is not a common relay, it is connected to ignition module sensing ignition impulses, which only happen when engine runs or started. I "outsmarted" this half way, my after market pump works when ignition is on engine off (not very good if bike is down)
