are there any other shut off valves that will work on 87 A?
I assume yours no longer shuts the fuel off? I'm not aware of rebuild kits available, maybe others here are. Other than snagging one off a wrecked/parted bike, what I would do is an in-line shut-off valve which should be available at about any auto parts store.
What's yours doing, or not doing?
Unfortunately, the '87 is a one year/model size, and if it's used on any other bike, I can't find out which one. So...
I drilled out the spikes that hold it together, rotated the little rubber disk inside and put some Teflon tape below the o-ring to stop the leak to outside.
Some careful drilling and tapping for reassembly and it works again, as it should. The o-rings to the tank are also some strange things but you can get away with normal ones there.
A simple and better solution is a 12V fuel cutoff valve. The advantage is that when you shut of the ignition fuel valve will shut preventing accidental hydro lock which can happen when a carbureted bike is parked without shutting off the manual fuel ****. Just install one in the fuel line and wire to a fuse that's only hot with the ignition on.
http://www.12voltfuelvalves.com/12-volt-fuel-shut-off-valves.html
Mine is leaking when off.... the previous owner added an after market valve on the right side and it is awkward to get to....................
It appears in my previous post one can say petcock but not c o c k.
Yes, no roosters allowed here. It can be a petcock but not a petrooster. :ROFL:
