Hello Jhook & welcome to the forum! I think you have a good bike there, just needs to be set right! The carbs are most likely out due to improper float levels. just 2 millimeters off will cause lean or rich conditions. When tuned properly these bikes are kinda like the space shuttle for power! Once re built properly, the carbs must be sinced for low end smoothness. You mentioned some popping. This might be due to sticking air cut off's in the carbs. I think your best bet is to pull them, Clean them out & re set your floats.
If you do a compression test, make sure your battery is topped up, throttle wide open, choke off & all 4 plugs out. You should see around 140 to 170 depending on the condition of your engine. Keep us posted!!!
