1 - 20 of 25 Posts
...Looks promising!
http://www.fuelmax.lv/info.php?lang=eng
Result of actions of the device
  • Reduction in consumption of fuel up to 20%
  • Increase in capacity of engine up to 5 Hp
  • Reduction in emission CO and CH up to 40%-50%
  • Purification of carbon-slag bloom
  • 7 years of unconditional work (service life is much longer).
About Super FuelMAX
The main elements of Super FuelMAX are magnets which are made on the basis of neodymium (Nd). Device consist of 2 equal parts. With the passage of fuel through a strong magnetic field leads to splitting the hydrocarbon chain into smaller components with their subsequent ionization, which in turn leads to more complete combustion of gasoline or diesel fuel. This type of magnets did not lose its properties over time, which shows an indefinite period of exploitation. Super FuelMAX — the compact and independent device, allowing to limit the consumption of fuel of vehicle up to 20 %, it does not demand any power supplies; at the same time considerably raises capacity of the engine and prolongs term of its service. Besides all this facts device considerably reduces emission of harmful substances in to atmosphere. Device is very simply installs on a fuel hose and this does not demand intrusion or any infringement of its integrity. If you decide to change the car for reinstallation will take 10-15 minutes. SuperFuelMAX RECOMMENDED to application on any type of engine of internal combustion (carburettor, injection system or diesel).
FUNCTION of the device:
Any kind of fuel, independently of where it is stored, constantly changes its substance because of influence temperature and humidity. Such influence extend and compress fuel. Finally, hydrocarbon molecules (a basis of any fuel) start to gravitate to each other and in such way forms molecular groups - «clots of molecules». Such "clots" can not be burn completely because part of them is out of reach for oxygen zone. When the fuel passes through the zone where is installed Super Fuel MAX magnetic-resonance frequency generated by the device, dissipates formed "clots" for individual molecules charging them positively. In such way the oxygen molecules penetrate into every molecule of fuel, which promotes complete burning of fuel-air mixture. As a result, this leads to lower fuel consumption and reduction of harmful emissions. Up to date, this effect can have only group of neodymium magnets made by special technology (USA Patent № 4.802.931, 4.496.395, 7.458.412, issued by the corporation of "General Motors").
Magnets from other manufacturers, if not to mention a cheap imitation, can not give such an effect.
Super Fuel MAX influences on gasoline, gas or diesel fuel, putting molecules in order, and therefore when molecules entering the combustion chamber area, fuel burns more efficiently.
Science
These results are achieved through more efficient combustion of fuel, which is possible only by special characteristics of a powerful magnetic field created by the device on the way of movement of molecules of hydrocarbons of fuel.
In scientific classification Super Fuel MAX belongs to a group of devices called "Magnetic-frequency resonators. They are widely used in various areas, but using of SuperFuelMAX principles of magnetic resonance for the ionization of hydrocarbons is unique. The alloy used in SuperFuelMAX for magnetic - frequency processing of fuel is protected by patents US # 4,496,395 and US # 4,770,723.
At installation of SuperFuelMAX on the fuel hose, the magnetic field becomes a source of resonance in the hydrocarbon chains, passing the liquid or gaseous fuel. As a result of hydrocarbon chain molecules are ionized and split into smaller fragments.
As a result, inside of the combustion of fuel, molecules enter the maximum separated from each other, what helps them better oxidation.
In simple terms, SuperFuelMAX on the basis of magnetic resonance "splits" fuel into smaller fragments, which has resulted in more "assimilation" by the engine.
By the source of the magnetic-frequency resonance are used conductors which are created on the base of the chemical element "neodymium" (in the periodic table of Mendeleev serial number - 60). They are producing magnetic field with 16 000 Gauss.
The author of Super FuelMAX is known American physicist and inventor - Robert Kane. First time he became famous 30 years ago when he invented radio pager.
Any info on a price or where to get it? People have been using magnets on a fuel line for as long as I can remember, I never tried it myself.
There is no science to support it. Hydrocarbon molecules are not magnetic. If this improved mileage even 1% every manufacture would install one before its EPA tests.
Still a winger at heart.
and while you are at it, rub some of this on to make your hair grow back.
Seriously, they mention "up to" a lot... .0000001 is part of that up to...
and just what is carbon-slag bloom? is that a biker valentine flower bouquet?
Banned
"...an indefinite period of exploitation"
Ain't that the truth. Probably the only truth in the whole thing.
I put two of them on my GL-1200. Now I get 90mpg at 80mph!!!!
Would I joke about this???? Would I ?????
I used to work for a company that made and sold magnets. We made the ones that went into BB guns and the ones that went into cruise missiles.
On a regular basis we would get a call from someone with a great idea that turned out to be either perpetual motion machine, quack medical cure or snake oil cure. There was no scientific basis for any of the above.
An auto magazine did a test of a number of these types of miracle devices and concluded that a set of new spark plugs was the best investment.
Banned
Filled the car up today.
Saw that the station is selling "up to 24% Ethanol" fuel.
Can he align alcohol molecules with them there magnetics? ..Well? ...Can he? ... .. .
I wants me somes E-magnets ...in 24%.
I've taken the bait on a couple of miracle devices in the past. I don't do that anymore.
i think i would get better MPG by just useing stright gas.when they added that corn i lost MPG. :readit:
Every time gas nears $4/gal the mileage boosters crawl out of the woodwork. Stand by for the bolt-on water to hydrogen rigs that promise amazing results. Perhaps if one of these were used in conjunction with magnets AND real gas we'd see some positive results...
Banned
I'm not understanding the "24%" decal posted on the pump. It does not state that it for use in Flex-Fuel Vehicles only. That's the Law. The sticker looks different than the 10% sticker. I grabbed the nozzle and had it pointed out to me before I started pumping thinking it was regular because I didn't notice the 10% sticker.
South Dakota isn't required to sell it. This station is selling it on their own. I know of no other station selling it.
I'm thinking this station is calling-in the special blend one tanker at a time. I'm also thinking that they are putting Ethanol in the regular unleaded tanks and not disclosing it to the buying public..
I'm no Crusader for the general public's well-being. But, I nearly put a 24% blend in my new Civic.
I've some alcohol testing kits. I'm going to use one of them on their regular pumps and see what comes up.
and what have you come up with , on your testing?
:ROFL:You can get the same results (better gas mileage) by magnetizing the deer whistle and rubbing it on the gremlin bell for one minute. Then soak it in a mixture of 50/50 MMO and Seafoam.
Money back guarantee if used with a car tire as well.
Banned
Hot dang that sounds reasonable. I'm gonna give it a try.
What? No WD-40? :ROFL:
1 - 20 of 25 Posts
