1 - 3 of 3 Posts
I have a 1987 gl1200 goldwing I have no power on the top end above 3800 rpm I have rebuilt the carps have NOT done a sync on them put a new clear fuel filter on it only fills up about 3/4 full when running is it is starving for gas at top end or is that right
1987 GL1200 Interstate
Have you checked the flow of gas by doing a pump test?
Also, are you absolutely sure your slide diaphragms are intact and installed correctly? Are the caps chrome?
Born in the USSR
Hi,
When the filter is 3/4 full it is not a problem. I think its not a problem with the pump but a problem of diaphragms. But before checking I would synch the carbs first of all.
Regards,
Sergey
1 - 3 of 3 Posts
