Ok, sigh of relief, I think. The recent maladies that I've been having on this 82 Interstate gl1100 seam to all have stemmed from float valves that weren't sealing, that allowed gas to fill the cylinders, ultimately, draining into the crank case. Had tons of white smoke, often couldn't even turn motor over, very bad gas mileage when it would run, 2 of 4 cylinders were cold fouled constantly, and the list goes on.
With everyone's help, I think I've got it licked, tore apart the carbs again, did external float leak test, they are now holding tight. The crankcase oil was very very thin, and about 8 quarts worth. I know exactly how much oil I put in on the last change, so the extra 4 quarts must clearly be gasoline.
So, what to do? I've drained the crankcase, will do a flush. Do I need to change the oil filter? Will gasoline ruin the element? I've read about 'fouled' plugs that need to be replaced---I'm getting spark, and they run, maybe not as good as it should (due to the carbs not being fully sync'd yet, and gas still all over the place. I'd figure that if they spark, they're good right? can a plug be diminished in ability after a significant fouling?
Having just finished draining the crank case, I'm hoping that the starter being hard to turn the motor over was a direct result of an overfull crankcase. The cylinders aren't hydrolocked (as they were very recently), so I'm semi concerned that either the starter has taken too much abuse, or that the gas did something else?
Fingers crossed, and oppinions/advices most welcomed.
Bob
Bob
