Do some searching on the site but you may have a bad float valve and/or petcock. Sometimes a few taps on the float bowls will knock a piece of grit loose in there.
Always turn the petcock off when the engine is off. If it has a slight leak, it may make it to the crankcase.
Do not start it until draining and refilling the oil. Also, remove the plugs and with kill switch on, crank it over to clear the gas from the cylinders. Cover spark holes with a rag. It will shoot fast and high. You can see the stains on my garage ceiling.
