I thought I had the mechanical issues straightened on my "new" 1989 wing. Went for the first real ride - over hundred miles- parked it and thought Wow I used almost a full tank :shock:! In the morning it was running weird when I went to fill up - getting ready for another day of wonderful riding. I was leaking gas like a sieve! Literally a line in the asphalt all the way up the drive. I put it on the center stand and watched while gas poured out from the overflow tube. I became familiar with removing the plastic and got it stripped down to where I could see the innards. When I removed the vacuum tube from the petcock the flow stopped. After a few minutes its stalled out - out of gas. I figured it was a stuck float in the bowls. Ran some seafoam full strength into the fuel line - let it sit for ten minutes - started it up and after the white smoke cleared - it was leaking but not flowing from the overflow tube. Repeated the procedure and it stopped :clapper:. My question is will this repair"hold"? I have a trip to western New York planned and want to feel confident. Guru's what do you think?
Thanks guys
Mike
1989 1500 wing 27K miles
Thanks guys
Mike
