No.
It is a waste of money to pay for the hi-test gas.
No.
I like his no nonesense talk
Seems to me Seafood is the same way . It cost more around the coast than it does inland ?...Next myth:
...why does it cost more to deliver gasoline to the retailer who is only 5 miles from the refinery?
If it won't run on regular gas, then perhaps there is something that is causing that. As that article states, regular gasoline has every bit as much BTU value as premium. Additivesto the premium merelyslow the speed of burn, among other things. Butan engine can have its compression ratio increased by carbon buildup in the chamber, built up to the extent that it may cause pre detonation(knock) with the faster burningregular gas. This condition will usually be countered by valve and piston ring wear which will keep the compression ratio down to a level that precludes pre detonation. Just my take on things from having worked with small engines a lot over the last 20 years.its completely stock and in mint shape,he claims it won,t run on regular but I am afraid it is going to have to get used to regular given the difference in price
What type of ignition does it have? Would an 83 have 'knock sensors'? Does it have a distributor? Could be the distributor is worn and the timing is off.its completely stock and in mint shape,he claims it won,t run on regular but I am afraid it is going to have to get used to regular given the difference in price
All 1100's have electronic ignition, no parts to wear out.andrewns5 wrote:What type of ignition does it have? Would an 83 have 'knock sensors'? Does it have a distributor? Could be the distributor is worn and the timing is off.its completely stock and in mint shape,he claims it won,t run on regular but I am afraid it is going to have to get used to regular given the difference in price
Now that's having your priorities in order.WING =Reg Cadillac =unleaded Lawn mower= reg. WIFE= PREMIUM $$$$$$$$$$ lol.
It may not be a waste of money in order to avoid ethanol in regular gas, especially in an older bike.No.
