1 - 3 of 3 Posts
I have a problem with my gas gauge on my 2005 Honda Gold wing does anyone have any solutions on how to fix the gauge on the 2005 Goldwing . I can fill the tank up but it still reads right around 3/4 of a tank full on the Gage
Remove the seat and disconnect the sensor 2 pin connector at the front of the tank. Ground the grey/black wire and turn the key on, the gauge should go to full, if not the problem is in the gauge. If it does go to full jumper the grey/black and the grey together, if it only goes to 3/4 the lower sensor on the fuel pump is stuck, if it goes to full the the main sensor at the front of the tank is the problem.
  • Like
Reactions: flylow
1 - 3 of 3 Posts
