1 - 3 of 3 Posts
mmonsterbuck
last weekend had gas leak found it, valve ahead of gas cap had small leak on bottom, rebuilt valve. but before that, had bike shut off opened gas cap and the gas was boiling in the tank. what causes that, wasn't hot outside, NO VENT CAP. so do i hold down clips and spray cleaner in center of cap. maybe vent pluged
Yah I doubt it was boiling. The flash point will be reached before boiling point. You may have a vacuum problem and the noise you hear is the tank burping air .
I do not know but well worth a BUMP
1 - 3 of 3 Posts
