I didn't replace my cover gaskets on the last belt change but did put a coating of Gasgacinch on them.
Gasgacinch Gasket Sealer and Belt Dressing provides unmatched gasket sealing properties, preventing leaks, reducing expensive repairs, and creates a superior grip as a belt dressing
Gasgacinch Gasket Sealer remains flexible and makes it easier to assemble and disassemble an engine or transmission, often any residue may be removed simply by rubbing it away
Adheres to carbon steel, alloy steel, aluminum, titanium, lead, magnesium, synthetic and natural rubber, copper and cork, and may be used in hot, cold, wet, dry, acid, basic, and abrasive environments
When cured, Gasgacinch is flexible, has high-peel strength, high-shear strength, fatigue resistant, vibration dampening, high heat resistance, gasoline resistant, and oil resistant
Preferred in nearly all mechanical industries including: auto repair, diesel and truck repair, high-performance engine builders, motorcycle repair and many more
