I see Dave's Cycle Supply sells what looks to be a quality combo gauge that indicates Volts / Gear Position / Air Temperature for the GL1500:
Where would the harness for gear position plug in and how difficult would the whole installation be?
Thanks guys.
· It aint rocket science
IIRC the connector is above the right side radiator with a few others. On a scale of ten it would rate about a two in difficulty with the usual plastic removal required.
Whenever plastic is removed it is always a good idea to do maintainance at the same time. Plugs, filters, coolant and lubing for instance.
