Greetings from sunny Australia, wish I could ride more often but there is this thing called "Work"
My 1997 model 1500 Aspencade bought in Australia has developed some secrets....been sitting for a while, one day started with difficulties, replaced battery, the usual and all went well....just too little use. Then no display panel ...fiddled....then no green light for neutral. Fiddled....put in gear and 'pushed back/forward'...got it going somehow. Next time worse...put in reverse....jiggled...pushed, in 1st pushed back/forward....it startet.
Today it let me down completely. Ignition on, oil light, temp etc is ok, but no OD or Neutral lights. Checked clutch switch per manual - works ok, sidestand switch is ok, checked reverse switch per manual - works ok, checked fuses - all ok, checked the black 6pole connector for gear position switch and measured approx 06.V for Neutral and approx 11.6V on all other wires (2nd, 3rd, 4th & 5th=OD)
Didnt check bulb of Neutral light, concluded that issue most likely is caused by faulty gear position switch, as there is also no light for OD.
From manual I understand working through gears each of the cables in black connector should turn to ~12V incl the Neutral position, mine does not. Mine shows 11.6V regardless of which gear is selected on all but Neutral.
My conclusion - the gear position switch must be broken/faulty. Does anyone have any comments?
What if I bridge out the switch by putting 12V onto the Neutral connector - thus fooling the switch so that I get the bike running to get it to the workshop?
The gear position switch is just inside the front motor panel - I have read removing this requires several seals, O-rings for water pump etc....seems rather involved incl oil & coolant change, struck me this is better left to the workshop?
Anyone any comments on removing the cover on a 1500 from 1997? How involved is it?
Hope to get some ideas from colleagues more experienced - I am at the end of my wisdom for today, tomorrow is another day.
Thank you for reading this, kind regards Hardy
