1 - 2 of 2 Posts
Is a 1980 gear shift Longer on a 80 interstate Than other goldwings. Mine Exstendes to almost over the top of my foot peg which makes it hard to get my foot in between. on a 83 I noticed it at least 4 inches in front of peg can i interchaged them.
Not all year Goldwings use the same lever. Now if you're asking if the '80 is different than the rest of the GL1100 Goldwings, likely not.
But if you find a longer GL1100 lever, by all means swap them out. You can also adjust the angle up or down by removing and putting in back on in another position. Could be you have a bent lever to start with.
1 - 2 of 2 Posts
