82 1100 asp.changed oil to 15-40 rotella.new fuel filter.new batt.napa added acid put it on slow charge.1.5 amps till charged,started fine.added fuel stable.went to start it.a couple days later flooded it out.put in new plugs.started fine.was watching amp wich comes up slow.stoped at13 volts with new batt.put a load test on about 13.2thought maybe stator went out.put battery on 10.amp battery charger.charged it about a hour.checked with load test back about 14.4 14.6. was that because new battery was not all way charged???or should i check something else...did stable cause the hard starting.never had any problem starting it. pull choke crankes about 4 times and starts right up.going to check it out today and see how it starts....also have done the three yellow stator wires....
