1 - 2 of 2 Posts
Discussion Starter #1 (Edited)
I want to start off by saying that this was a collaborative effort,
I did not do this Alone.
And,
My Bike, is not the only Bike, that is Running Great Now, with this Exact or very Similar Single Carb Conversion setup.
This Single carb. Setup, is a Formula for success, out of the box success, with the 32DFT 2-barrel Progressive Carb. No Jetting at all, all i did was, remove the Elec. auto choke (It is Not needed) start the engine, and set the Idle to 1000 rpm, Then inspect for leaks, air up the tires and Go for a Ride
Weber 32 DFT (Same as)
Manifold Runner Kit - Type 3 & 4
typical throttle hookup parts, empi uni link kit
some folks say the 32dft runs great as is, other folk say runs rich at idle RPMs & needs tweaking
some folks say intake needs heat, others say naahh....
Aside from myself, none but one have put a coolant chamber on a Empi plenum to heat it as Tom directs.
...to each their own.
one big reason for varying results is folks who are interested in scc are often tinkerers by nature, and like to try different ways/approaches to intake manifold setups, here's easy
what is the best, easiest intake runners setup with the westgl scc
vids
a-z
vids of running bikes, tutorials etc
Discussion Starter #2
changed the focus of this thread from
"pls post links to langdon based scc treads here"
to current title
1 - 2 of 2 Posts
