I am thinking of putting an 81 1100 motor in my 76 1000,will my 76 carbs and coils work on the 81,it has no carbs,what else might i need,thanks in advance
They should bolt right on... try it, see how it works. The 1100 carbs, however, are more forgiving when it comes to tuning etc. The coils should be fine.
The Irish Crew
How will you get the 1100 engine to work with the GL1000 points setup? Or is it possible to get the 1100 engines electronic ignition to work on the gl1000?
my 1000 already has a dana electronic ignition in it,with any luck the 1100 ignition will work,i am not sure what else might match or not match,still gathering info on everything
Simply a matter of consulting the wiring diagram and modifying it to work. The coils should work regardless... might have to change the ballast resistor for the electronic ignition.
Electronic ignition only replaces the points and condenser.With the electronic ignition you'll have to find outhow it's getting power, which leads go to which coils, and where it's grounded.
