1 - 3 of 3 Posts
PO had tank cleaned and then coated. this coating has cloged the screen on the bottom and will need to be opened up again ... Very little to no gas coming out of the tank... Air is going through the tube down to the screen... what suggestions do you have??? :):):)
Quite a stable you've got there. I would try Acetone. You'll need to keep rubber and plastic parts away from it though. On an 1100 you can pull the sending unit out after you remove the seat. I'd pull off the petcock and fashion something to plug that up as well. LOL!!!
when i coated my tank , the csreens also pluged up. i used a speedo cable inerders (inner cabel part ) to ream out the lines going to screen and put a hole through the screens on both tubes. just watch witch way the cable is turning , so it dont unwind. getting it to pass the bend is the fun part. good luck with it.
1 - 3 of 3 Posts
