Can an out of sync carb cause a noticeable knock at idle? My 81 Interstate has developed a very noticeable knock after not being ridden much over the last year. It will start and will run if the the throttle is feathered from a dead stop, and under power the knock disappears and the bike runs fine. Thanks for your help.
Yeppers, it's known to happen often. Get the carbs synced and idle set then see if it goes away.
Guru
Give er a big drink of sea foam in the tank as well. You might have some gummy carbs!
welcome to the forum, This is the best place on the internet for good advise, good people & a few road trips with members if that's the kind of thing that blows yer hair back!!!
The primary chain, the one that goes from the crankshaft to the transmission flops around and makes quite a noise if the engine isn't idling smoothly. Just the design of it.
Q
mine done samething.used sea foam in tank about 3 tank full.now it runs fine.you may need to change air.fuel filters,and plugs,if its been awhile.change.timming belts.oil and filter also.
