I have a 1983 Goldwing Interstate GL1100with radio problems....I have the original clarion radio. I can hear the radio in my helmet but it is very low, I cant hear anything coming from the speakers. I have had the bike about 5 years and just had alot of work done to get it back on the road. I would enjoy it even more if I can get this problem solved. Any help would beappreciated
Welcome to the forum Mickey
Have you tested each fuse behind the left turn signal? Could have as many as 7 if all the accessories are on the radio of the Clarion 2. Test them with a multimeter to be sure you have 12volts both sides of the fuses as they can look good & be bad.
Thanks Stu...when I opened that up today it looks like a wiring nightmare, all I did was look at fuses but didnt check them with a meter. I will do that tomorrow
That's the place to start. Replace them if any doubt.
Which parts does it have besides am/fm? Intercom, CB, cassette tape?
Check the mute button is it on..or off but stuck on?
Thanks for all the advice...Question?...I know the mute button on the radio works....is there a mute button on the handle bar switches? I have one switch that the letters are worn off.(Top right)
