:walker:Just a quick note on side stands. My 83 Aspencade was leaning over way too much, compared to my 83GL1100 Standard. Measured to side stand and found the Aspencade to be an inch shorter. 8.5 vs 9.5. I switched them and now the Aspencade is more upright. If any of you have the same problem, see if you can find a longer stand.
I will be syncronizing the carbs this weekend, as well as changing the coolant, oil and rear end oil. I should be ready to ride, if it doesn't rain. Yes, we get rain in San Diego. Now I just need to figure out why my radio does not work. The clock does, but no sound from the radio. I suspect a bad ground since it worked when I installed it.
Jerry:15red:
Jerry:15red:
