1 - 13 of 13 Posts
WTB GL1100 complete set of spark plug wires. Prefer new, OEM, but open to discussion of same. I have found 7mmm copper core, but only in racing colors, like red... I would have to get spark plug and coil ends to fit, does any one have a good idea of where to source?
· Still Learning
No one sells new sets. You just buy the wire, spark plug caps (NGK), reuse the coil end caps, inner metal pin, outer plastic compression sleeve.
Thanks, that is what I was afraid of, but it seems no problem to do it that.
· Itinerant Wing Preacher
4 cylinder tractor wires work well bought a set of universal ones for less than 20 last year Jay
Thread on wire replacement.
Here is a thread on my wire replacement during an upgrade to a neon coil. I had to make my own set as well. There is a post of the parts I purchased, where I got them and some tricks to keep it stock.
I wouldn't recommend using the original caps. They have a resister in the caps that can go bad over time. I haven't found where you can purchase just the resistor but I didn't try very hard.
Good luck and let me know if you need anything.
http://www.goldwingfacts.com/forums...lternative-gl1100s-probably-1200s-too-16.html
· Still Learning
· Still Learning
Discussion Starter · #12 ·
Scott, I will take the speedo and wires, would not mind the stereo box (that holds the stereo) if it is in good shape. My email will be in a PM to you.
Discussion Starter · #13 ·
1 - 13 of 13 Posts
