Need help from my Goldwing brethren. Came back to the bike ( 1981 GL 1100 Standard ) an hour after an uneventful 20 mile ride with all systems functioning. No power with the switch in the run position. Aftermarket voltmeter shows 12 volts with the switch in Park position ( all the way to the right ) and tail light is on. PO had installed a 30 amp circuit breaker to replace OEM 30 amp fuse. Bypassed that - nada. The infamous 3 yellow wires forward of the battery are in the original connector and appear OK ( bike has always been garaged ). All auxiliary fuses in fuse box are intact. Buddy with a real tester and more knowledge is out of town. Any and all advice or suggestions are welcome.
