1 - 11 of 11 Posts
Junior Grue
It will fit however there are some wiring differences.
Your 84 had the pulse generators in the rear rather than the front and the Aspencade has six wires coming from the gear switch rather than the three on your Interstate.
All this can be overcome. Also the 85 and later GL1200's are lower geared than the 84.
Thank to all my 84 has motor noise and after you ride for a short whileit has tapping.sound from valve train. I found the 86 aspy with 30 000 on it but hasn't been starts since2007. Carbs are froze up but motor turns over were is the switch gear located
Junior Grue
The gear indicator switch is inside the front transmission cover next to the water pump.
There's likely no reason to change it, just cut the six wires and connect the three you require to your old plug. The colours of those required wires are the same on the Aspencade and the Interstate.
Discussion Starter · #8 ·
My valve startsoff q.uite after riding a while left side has loud taping sound that comes and goes I have replaced lifters and shimed to spec also gauged rocker arms. When noise starts I let off throttle AMD noise stops for a while
Actually that is pretty common on the 1200's. Some bike do it some don't. I've had 3 1200's and only one of them did it. Usually I notice it after sitting at a red light then I pull away and about the time I hit second gear it starts rattling. Only last 1 to 3 seconds or so. I was worried about it at first but since then I've learned that some of the 1200's do it without any apparent bad effects, other than the noise, so I pretty much ignore and expect it. The 1200 was honda's first foray into hydraulic lifters and I think they got it right on the 1500. Maybe not as they went back to mechanical lifters on the 1800.
I do know that the more I ride the 1200 the less it does it. So the real "fix" for the noisey valves is to ride it more!
My 86 interstate has a 6 wire plug for the transmission plug. I put an aspy motor in it and it had the No wireing needed. The pulse coils are different. But I'm not sure about the gear ratio. I thought all 1200's were the same.
Junior Grue
As far as I know all Interstates had three wire gear indicators, N-4-OD. The wiring diagrams in my Honda manual say so.
And yes the 84 was a one of gearing. That was changed in 85-87 supposedly for better fuel economy but are lower geared than the 84.
Takes the edge off I want a sixth gear doesn't it.:?
1 - 11 of 11 Posts
