On my recently-acquired GL1200 I have a recurring noise that is happening. This GL1200 was just purchased to replace my other one. It's an 84 with only 28,xxx miles. So I am running this beast much more than the prior owner did, for sure.
As I'm not that great describing it I'll try my best. Bear with me.
First off, (perhaps related, perhaps not), if you're "at speed", say 70 to 80mph, and accelerate it - you have to be easy on it. If I accelerate too much it kinda stammers, sputters, or whatever you'd call it. If I back off and accelerate more modestly it does fine.
I've run one can of sea foam already, and sync'd the carbs. I will resync again in a couple of hundred miles just to see if they're changing.
Now on to the noise. This one has me vexed.
No pattern to this one that I can tell. Every 10-20 miles or so, it will make a noise, seeming to come from the engine area, that sounds like...... uhhhh.... a bicycle with a playing card in the spokes.
It doesn't last - and quits shortly after beginning.
I don't get it.
If this thing is gonna "crater" (throw a connecting rod, or bend a valve) I would think it would have done it already. I'm open for thoughts.
I don't get it.
