1 - 13 of 13 Posts
I looked at a guys 1200 today, (gonna change the timing belts) . went to adjust the seat for him and it is way different than what the help video shows,( the video and tutorial from this site) to adjust his seat, you open the fuel door, and there is a lever in there ( NONE AT THE BACK) I thought they where supposed to be the same as the 1100. this one is a 84.
Has anyone else seen this, or am I just all wet behind the ears ?
I read through your post and the minute I saw fuel door, I said "must be an '84". As far as I know, they're all like that. 85 and later are on the left side rear.
Vintage Rider
Seat Adjuster? My '85 has elongated slots on the rear seat mounting brackets, you have to loosen both mounting bolts, and slide the seat by hand, then retighten the bolts. If you move it all the way back it leaves quite a gap between the front of the seat and the fake tank.
1987 GL1200 Interstate
Yours is missing some stuff, Jerry.
There should be some electric motors, springs, a pully and two toasters in there. I think the sink and faucet are on the right side.
Oh wait, maybe it was just a spring loaded, hand operated latch. The right side has a special bolt/spacer to keep the seat stable but still allowing it to slide.
So what model had the toasters?...Damn, now I'm getting hungry!
so the 84 is hondas one off special ?
What else is unique, before I get to involved with this guys project, How about changing the fork oikl on a 84, where the heck is the drain plug?
Fairing and pulse generators are exclusive for the '84. Timing belt covers too, I think. And maybe the heads. Lots of things are '84/'85 only.
Bottom line is research before you buy.
Vintage Rider
The rear wheel is also different for the '84 and '85, they made some major improvements for '86, so the bearings wouldn't move around and destroy the wheel. I had to replace my '85 wheel with one from an '86 or '87 for that reason.
Discussion Starter · #11 ·
thanks for all the input, but where it the .... is the drain plug for the forks?
Discussion Starter · #13 ·
hey thanks I did see that , I guess I will have to remove the top cap to fill it, cause I don't have a pressure fill system any more
1 - 13 of 13 Posts
